1957 Oliver Super 77
Mark Murphy
08-09-2005 18:39:35
I want to lower the weight of my Oliver Super 77. I have been told I can lose over 200 lbs. by changing the bathtub to one from an Oliver 77. I would like to know how much more I could lose by also changing the rear-end. Pleae advise!!!!
MCL
08-16-2005 19:24:26
 Re: 1957 Oliver Super 77 in reply to Mark Murphy, 08-09-2005 18:39:35
I have a 1953 77 with hyd and pto intact. Belt pulley gearbox is gone. Pressed steel all the way around with 14.9's and it weighs 3900-4000 depending on whose scales I am on. That is with me on it and I weigh 175.
RichB
08-10-2005 09:44:45
Mark I pull a 77,1949 has the old style band brakes,I run 3500 with 18.4x34 tires and I weigh 200lb,the super rearend has disk brakes so that ads weight,take off hydraulics PTO etc,If it was me I would find a old 77 and work with that,Email me if you want,can give you my number If you want to call also RichB
Robert Mark Murphy
08-18-2005 13:29:32
 Re: 1957 Oliver Super 77 in reply to RichB, 08-10-2005 09:44:45
Thank you for your response. I have done considerable reasearch and keep coming back to the idea of finding a 77 chasis with it's drum brakes and lighter bath-tub.
Thank You
Mike Bray
08-10-2005 03:04:23
Mark You can lose weight if you can find a 66 narrow front or build a home made wide front.Are you on pressed steel on all wheels. Take the belt pulley & gear box off. Hyd cover, pto. Not sure now low you want to go? This should get you under 4000lbs. Mike
