1946 JD B
Farm w/Junk
04-15-2005 22:38:44
Hey all got a JD B I would like to pull couple times a year plus work around farm and plow days. Looking for couple more ponies to get her to work. Any ideas? It is an all fuel model. How much are aluminum pistons? Or gas? Thanks for your help.
Matt
KEDDANO
04-29-2005 20:48:22
 Re: 1946 JD B in reply to Farm w/Junk, 04-15-2005 22:38:44
The '46 has the high gear trans in it,not good.Also if it has cast rear wheels and pto,electric start,three point,fenders,you'll be at just under 4500#,also not good.But with work and a diet....it's still fun,with some bucks,look out
JerryBird
04-16-2005 05:39:11
Aluminum high compression pistons along with a gas manifold are going to give you the most bang for your buck.After that there are countless other things that can be done ( carb modifycations, upgraded ignition, reground cam, etc...).I would suggest calling Triple G Service .They will have the right parts and sound advice to help you out.Thier numbers are 1-716-542-3175 and 1-888-720-0830.
