1950 John Deere A
cody
08-22-2003 20:36:42
I recently bought a 1950 JD A. how can i check to see if it has a power block? would it pull good in a totally stock class at a tractor show? if it didnt have the power block how would it pull? if it did have a power block how would it pull?thank you for any info!:)
Richard
08-24-2003 08:44:13
 Re: 1950 John Deere A in reply to cody, 08-22-2003 20:36:42
I have a 1952 A and yesterday (08-23-03) I pulled 5500-6500lb. with 18.4x38 cut tires. My A is stock with a power block. I didn't lose hardly any rpm's so good luck pullin'.
a puller
08-23-2003 11:54:57
a powerblock has no petcocks(compression releases) in it and it will give it more power, but doesn't effect the way it will pull in low.
52 A Boy
08-23-2003 06:06:42
I have a 52 A that is bored .125 with aluminum pistons and ive run in the 8100# class and still lose traction, im running 14.9's, if you have the creeper it will do fine.
52 A Boy
SB
08-22-2003 21:10:00
i have a 1950 jd A i pull with, if it has a powerblock it will be stamped on the block behind the manifold, unless someone ground it off. or it will sound alot deeper. my friend pulls a 52' Jd A with a powerblock, we both run out of traction before power, mine is totally stock and i pull up to the 6500# class.
