I have been doing a lot of research on the
88 diesel motor I have one I bought at an
auction cheap with 2 heads tractor will be
strictly for pulling I am looking to run
it yet on diesel with a roosa master pump
and rebuilding a set of injectors with new
nozzles and resetting the opening
pressures to spec. My question is would I
be able to run 4020 lp pistons that have
the same wrist pin dementions and getting
away with cutting roughly .350 off the
piston tops to make it to the correct pin
height? Or would I be better off making
the motor a 283 over the 341ci? Anyone
ever build one before and have any input
really want to stick to a diesel since
tractor originally was a diesel. Thanks in
advance
advance
