IN560
What?s a good clutch to run with a stock 301 in a 560?
Also I plan to keep it stock for awhile. Do I need to run a heavy duty clutch or regular duty? Thanks
I am running a new standard button clutch disc with a old standard pressure plate. No sign of it wanting to slip. 110 hp 15.5 top cuts 3.5 mph
Thanks Lee460 that?s exactly what I?ll be running.
Do you recommend a Hy-capacity clutch? I?ve heard good
things about them.
For your clutch give clutch dynamics a call in Lansing Michigan, he set me up with an Oliver 88 clutch reasonably priced and is knowledgeable on all clutches
