John Deere B
whigg
If I strip everything off of my 1950 B narrow front end is it possible to pull in the 3'500 lb. class with a 200 lb driver. Thanks for any help.
yes, you can get there easily . it won't hurt either if you get the power of a 520 somehow .
its NOT easy but yes you can, ours weighs 3500 exactly with a 230# driver. 15.5-38 tires. had to use a tiny aluminum radiator- went from 8.5 gallons total down to 2.5, lost the fan, fan shaft, charging system, water pipes etc, lightened the stamped wheels, lost the gas tank, sheet metal rear cover, small wheels in front.
