16x38 aluminum wheels
JDJim
Anybody know roughly what the weight difference is between 16x38 9 bolt pressed steel wheels and aluminium wheels? Thanks.
While we are there. How do Cales steel wheels compare to aluminum. Also the spoked ones with a light weight steel wheel. Thanks.
lite weight steel are in the 87 - 92 lb range,my Nearpass wheels are 100#,some other al. are less.you safe about 80 lbs per wheel,more on some heavy steel
Thanks. My pressed steel dual wheels weighed about 165 per wheel. To heavy to use them for me. I'm just going to pull 5250 and lower.
