301 carb on a 560
I don?t see why not just run screw in till you get it running right... I?m not sure diffence in venture size from a 806 to 560 but I?m sure someone will chim in
Thanks mfro75. Someone told me once that it was a little bigger venturi but didn't say how much bigger. I got 1 I'd like to try one it and see. Just need a little more ponies.
Yes it will work perfectly. Like mfro said just dial it in. But if your 560 carb is correct and the 301 carb is correct you most likely won't see and gain on a stock 263 engine.
