Farmall C c-153 Spark Plugs
Hey guys I was going to put some new plugs in my C and I was wondering what everyone's opinion is for the best plugs. its a farmall c with a C-153 engine, I only use it for pulling. I usually run 3000lb-4500lb and don't run out of power but I just want to make sure I have the right plugs in it. it has acdelco c87 in it now.
ya for sure,bought a new tractor that had a new srater solenoid,one lug had the thin Jam nut only on half way,one and a half threads,seen it from day one,bothered me that the nut could come off,so after several monthes of looking at it,my mind said fix it,so took off the nut and a lock washer from behind the wire,put the nut back on,it only turned as far as it had been on,so held the back nut with a wrench,pulled harder till it tore the treads and galled more,-- THEN BROKE THE BLACK BAKELITE COVER ALL TO HE*** !!!!!!!! Then had to remove starter( have protective explosion blanket) and dilly with it for two days.Now have new lug and new cover,but way too much trouble for something that wasn't broke.
(quoted from post at 11:02:17 07/12/18) Hey guys I was going to put some new plugs in my C and I was wondering what everyone's opinion is for the best plugs. its a farmall c with a C-153 engine, I only use it for pulling. I usually run 3000lb-4500lb and don't run out of power but I just want to make sure I have the right plugs in it. it has acdelco c87 in it now.
I run Autolite 388 plugs in my C153 and my H, put new ones in at the beginning of every season, they work for me.
