VicS
Location
SE Il.
I've worked on this thing for maybe 4 years off and on. Had it together twice. Stock 426 motor. Not enough. Waiting on a better one! While I'm waiting trying to loose 250 lb.
are you building one of these ? https://www.youtube.com/watch?v=fRaO86Vg9dg&list=PL7LSAj1dWJse3zmwFEZ0lBAYQVZP9tDEI&index=5
don't know how to fix it for you it's www.dragonpulls.com , go to points select v8 modified then youtube and glady's 2017
Dont know how your computer is set up but mine if you hold the left click button down and swipe the web address, when blue, click the right click button and a box will open with options and one of them will be the web address, click on it and it should open. I hope newer systems operate the same as I am using Win 7.
it's not mine , but a friends, they run open class . it is fun to watch . I thinks they run up to 5000 lbs.
Thanks. I am on a phone. But i finally figured it out. But I'm building the D17 to run in the 4200 lb. To 5200 lb. Baddest antique in the world. 8mph. That video was just below. Think my friend Jack Webb won on a 770 Oliver.
Some places 2650. Cam will pull to 3500. He has the block done now. Needs a few days on the crank. Has it roughed in now. But he is farming. I am too.
