bolts for rear weights
what size and how long of bolts to hold oliver rear weights on rim's. I have seen where guy's use just two long bolt's. Does this hold them? I have 6 150lbs weight's I would like to use. Thanks.
If you just got to use them instead of clip on weights, make you a pipe or something they will slip over. I have even saw a big pipe they slipped into. That way you can add weight or take some off without killing yourself. That said you can just use two or three long all threads. Put nuts on every one.
Drill your weights to 7/8. Use 3/4 all thread bolted tight to wheel. Measure for length. You will have no problem with three sets. We bolt on up to 6 sets. Email for more info if you like.
