Weight Loss for Oliver 88
Can anyone tell me how much weight I will lose off my Oliver 88 by removing cast front rims pto and hydraulic pump? Looking to get down to 4500 lbs, currently weighs 4650 with 15x9x38 tires on steel rims. Thanks!
Ours weighs around 4300. Pressed steel rims with 18.4x34. cast front rims. Still has pto. Has no hyd. Custom made seat bracket. I would say you should down to that with removing what you listed. What did you ever do about a cam ?
you will easily lose over three hundred,depends on what you put back on the front for rims,bearings and such,I made mine with heavy tubing and oil lite bushings,weight about 7 lbs each
thanks 300jk. just ordered a cam for Maibach Tractor. sending it to Bullet in Missouri to have it ground. hoping to gain more torque. how much weight do you think i will lose with what i posted?
Mine is a Super 88,and have pulled at 4200# with all brackets removed with 13.6 x 38 tires,and I weigh right at 230 dressed,so you should be able to do less with a regular 88
Colonel1958,Bullet Cams is not in Missouri,It is in Olive Branch Ms. Bullet Racing Cams 8785 Old Craft Rd, Olive Branch, MS 38654 Phone (662)893-5670 Fax (662)893-6056
