9 Bolt Hubs for Moline GTB
Are there any bolt on hubs that fit a GTB...don?t want weld on and I know Cap Bros can make them...just looking for something that may
already be available...Thanks for any replies.
Are they 3 inch axle? The one I had was. If so: you can use a 3 1/8 hub and use a piece of exhaust pipe to shim it up. You will have to build your Key since the axle groove is tapered. 3 1/8 can be found ( I currently have 3 sets). 3 inch near impossible.
Guess it should be added: that is the later model GTB. The earlier models with the axle brakes do not allow that option. I was assuming it is the later model with the Moline 8 hole hub you want to change.
