RPM FOR FARMALL B
dstray
New User
Ok we are only allowed to set the rpm at 10% over stock witch is 1640 for the farmall b . My question is at what rpm does the little 113 engine have the most tourque ?
I was told it was 2150 guessing thats a little high.
2100 is probably ok but your not going to get much out of that.
On a transfer sled you might see a little bit of an advantage because of a little more speed but it wont make any difference on a stone boat.
So are you saying 2100 is to much And should keep it
around the 1700 rpm for maximum torque and hp
I don't think the carb will flow the fuel for good power. If your running a transfer sled its a good idea. For stone boat it wont do a whole lot.
We are pulling a transfer sled. I do have to be careful what I write on here because there are club members that watch this sight that we pull against. We do run a stock carb and do ok with the tractor just heard that the 113 engine put out its max torque at 2150 . thanks guys
