Weight of A-C WD
Earle(NC)
New User
Can someone give me an idea of what a stripped down (no hyd/lift) WD, wide front end, no loaded tires, would weigh? Thanks in advance, Earle
Depending on your definition of (stripped down): I frequently see them pull in the 4000# class. On occasion, 3500. Also deduct 150# or more for driver for tractor weight.
Like I said m y 45 weighed 3880. It sounds like you want to pull with it. Our club won't let you take off much if you pull farm stock. If you change out wide frontend for narrow front end,delete hand clutch, take all hydraulic ( including arms), remove PTO, lights. and build a light weight seat you should be able to get it under 3500 lbs easy.First photo is mine when I brought it home and second and third is it weighing in at 5500 lbs.
