460 farmall ta puller
mfro75
I am building a 460 puller I have a hy capacity ta installed. Deleted the power steering and hyd pump... my question is if I plug oil galleys in ta housing where oil runs back to trans will it stay or escape out the back of the ta? I?d rather do it this way instead of using electric pump to lube the ta.... but not sure oil/ hytrans will stay put any help much appreciated....thanks Matt
Leave it like it is that oil will swing around and get it in the Trough run down into the ports lube the ta did you take pto and shafts out
