Division II wheel hub rule
36 A
From natpa rule . APPEARANCE - Tractors must maintain original stock appearance. If a part is not found in the manufacturers? parts book it cannot be used. No extra accessories allowed with the exception of weight brackets, hang-on weights, wheelie bars, wheels, rims, bolt on hubs, draw bar, muffler and air cleaner .
Can I make a 9 bolt hub for my tractor or dose it have to be a stock part ?
I just looked up.div rules. It says you can have bolt on hubs. Doesn't say you can't have weld on hubs. But I give Jason. I never thought about anybody wanting to pull non.cut tires.against some spun backward 10 hrs tires. LOL The tires I pulled 2 yrs ag0.was pulled the year before as un cut.
Doesn't say I can' either.
Let me put it simple. Weld on hubs aren't legal in Div 1 or 2.
The tires I have run have never been spun backwards. And I do just fine.
John Deere made a ten spline hub but they are spendy . I want to use the splined hub and make a plate to slide on the tapered hub and bolt it .
You will be fine as far as NATPA Division 2 with your hubs & adapter plate. Another option is the hubs Pete Petznick @ Cap Bros. (816-308-8879) makes. VERY well built!
