Yesterday's Tractor Co.
Shop Now View Cart
TractorLinks.com
hitches angle and thoughts why
slowmo57
01-02-2018 04:15:49
hitches angle and thoughts of every buddy
I have seen a lot of different hitches over my 38 years pulling.
Cheating ones (floating )
Pitched up hard pitched down hard strait hitch no pitch because of groups rules.
Long hitch 20 from center (said because pulling on hard or soft track to get frontend to lift)
18 on dot more down pressure Height up and down always max unless front is light and no way to move any more weight to front
Really wide hole where chain goes Oval hole round hole
square hole hitch in line with hook point
Everything works good for every one differently . I know I must of missed some areas of hitches. Why does one person work good or is it just his hole set up and driving skills?I SAY YES TO THIS ONE. This is some things me and some of my puller friend talk about. Anyone else ever do same.?
showcrop
01-06-2018 13:08:33
 Re: hitches angle and thoughts why in reply to slowmo57, 01-02-2018 04:15:49
Pitched down hard? If the hitch point is 20 inches high and close to all the way back you must have to attach at the top of the rear housing. I have seen hitch bracing that comes from high up but every drawbar that I have ever seen comes from under the housing.
Curt Smith
01-06-2018 10:38:52
Angle makes no differece. Its how and where you bolt it up. Your 3rd bullet point is on the mark.
oros35
01-04-2018 07:47:12
As long as the hitch is fixed and can't move, the shape or design of the hitch doesn't matter. Pick up an engineering statics 101 book and start reading. Build your free body diagram and it will be clear. It doesn't matter how you get from point A to point B on the diagram, the resulting forces and moments will be the same.
Only time it would make a difference is if the hitch point would move in relation to the tractor during a pull. Which is illegal everywhere I've ever pulled.
What you want to do is design your hitch to meet safety rules, keep the weight down, and have it as adjustable as possible. Moving your hitch point 1/2" up or in makes a huge difference in how the force from the chain gets applied to your tractor.
20MuleTeam
01-04-2018 14:44:06
 Re: hitches angle and thoughts why in reply to oros35, 01-04-2018 07:47:12
Exactly correct. Took Statics 101 55 yrs ago & that's what was taught. Still true today.
mmfan55
01-04-2018 06:56:38
Hitch design does make a difference. Again, not a one size fits all situation. Takes some experimenting.
535353M
01-04-2018 16:57:03
 Re: hitches angle and thoughts why in reply to mmfan55, 01-04-2018 06:56:38
MMfan55, I agree with you !!!!!!!!!!!!!!!!! Makes a huge difference,we have all used a crow bar to lift stuff,angle matters most.
mmfan55
01-04-2018 18:07:37
 Re: hitches angle and thoughts why in reply to 535353M, 01-04-2018 16:57:03
Thanks 535353M. I have built several U moline tractors and experimented with different hitch designs. Some I pulled a few times and changed the hitch to a previous design. I will not debate what self proclaimed experts write in a book. I know what experience taught me. Experience says it makes a difference. Same model tractors. Accurate comparisons
JDTH
01-05-2018 04:56:51
 Re: hitches angle and thoughts why in reply to mmfan55, 01-04-2018 18:07:37
Agree with both MM & 53! There is a reason NTPA & PPL limit the angle of the drawbar.
showcrop
01-03-2018 05:54:31
What you want for a hitch is a "transfer hitch". I believe that two brands of tractors had them. The drawbar is mounted in a linkage that causes it to pull up and out when when the load comes on. These are especially helpful when pulling light and your tractor is nose heavy. It is not recommended though unless you have a close relative or good buddy on the scale or running the pull. :wink:
slowmo57
01-03-2018 10:38:21
 Re: hitches angle and thoughts why in reply to showcrop, 01-03-2018 05:54:31
LOL Showcrop
I don't want to cheat. My post was just to see if anyone thought any style hitch built gives a advantage over another one built. Just some fun talk among fellow pullers.
VicS
01-02-2018 06:38:28
Slomo I don't think it makes any difference the angle of your hitch. It's all solid steel. But because of some rules on my Allis I have welded a flat plate to make hitch level. Rear end of.a.Allis is way higher than 20". Just a tip from your picture. Keep front wheels strait when off the ground. When you come down acts just like a brake. Lean left to make tractor go right. Sorry just helpful hint for.today. Have I pulled with you on my 435 JD.
slowmo57
01-02-2018 07:48:53
 Re: hitches angle and thoughts why in reply to VicS, 01-02-2018 06:38:28
Yes, I remember your 435 JD tuff tractor. I built Slow Mo 20 years ago. How long have you had 435 JD ? I know it has been a long time.
VicS
01-02-2018 19:02:53
 Re: hitches angle and thoughts why in reply to slowmo57, 01-02-2018 07:48:53
I think 8 years.
slowmo57
01-02-2018 07:35:00
yep I agree about front tires,that is my 15 year old nephew in pic.he has been pulling for a few years now.He was a little nervus pulling inside for first time.
mdross
01-02-2018 06:19:03
Our club's rules say where our hitches can be and how big the hook hole has to be. The hitch I built attaches to the tractor on the draw bar frame and triangulates up to the rear axle housing. Changing over to it from a modified drawbar has put me in the winners circle a lot. The rest was weight placement.
