(quoted from post at 12:48:42 12/23/17) I took the plunge and purchased a pair of 16.9 Firestone F/R with 16" rims. These tires should not hurt gearing too bad and the extra width adds up to a little more bite once I get the tire pressure dialed in. Weight placement is always fun staying on top of. Ive set the tractor up now so I can run in two different classes 7000 & 7500 lb.
(quoted from post at 12:28:29 01/08/18)(quoted from post at 12:48:42 12/23/17) I took the plunge and purchased a pair of 16.9 Firestone F/R with 16" rims. These tires should not hurt gearing too bad and the extra width adds up to a little more bite once I get the tire pressure dialed in. Weight placement is always fun staying on top of. Ive set the tractor up now so I can run in two different classes 7000 & 7500 lb.
I have a set of Michelin BIBAGRIP (from overseas) in 16.9-38 on 16" rims. I can't wait to try them over the 45 degree 14.9 Firestones on it now!
