I am ready to bore and stroke my 426 Diesel which is in a D17. It is a NA motor no turbo. Just looking for cheaper options than buying custom pistons, rods, and billet crank. I have the head at the flow bench place. Also have a cam, done by Vogel Manufacturing . I have learned you can take a 466 IH crank and offset grind it for a 5 1/2 stroke, using Allis rods. Kinda involved, the thrust bearing is in the wrong place and would need a IH flywheel. So if I use IH 466 pistons also 4.59 which is 546cu in. What I can't find is what is the distance of IH piston from pin to top. Also what AC piston is from pin to top. Or where you look to find out what various rods sizes in common engines are. If anyone has ideas I am listening! Thanks Vic
