Have good motor for 4010/4020
larryanderson
Probably should be in classified but have an excellent turbo charged 404 JD motor currently in JD 7700T combine.Runs excellent and is still in combine so you can hear it run and also drive.The combine is good but not much value to use in our area.I was told that is a near perfect match for 4010 or 20 and would make a cheap pulling motor to put in a gasser Thanks located in Iowa but could ship but prefer you hear it run first.Rest is probably going to salvage.Thanks
