Oliver 1850 Injectors
ljm
I pull with an 1850.
I need to replace the injectors. At least the injector nozzles.
I would like to get to 110 PTO hp. without adding a turbo.
Anyone have recommendations on what injectors I should use?
Just need to take your pump and injectors
to your local pump place and set the fuel
curve there. No problem. But will need
to rev it up a little. May need a
different governor spring.
