trying to understand the rules
chuck machinist
If my tractor "Bone stock weight is 6300 lbs, what weight class would I enter,and what leyway do I have to stay within that class? aka a ROOKIE .Be kind, just trying to learn.
yes , I spotted your tag in the Elizabeth river on the members map riding a 400 case , hope that's right . the central va tractor club is having a pull in your back yard at the Isle of Wight
fair on Sept . 16 2017 . the first class you can pull would be 7000 lbs class . you may not have a hitch height of more than 20 inches and of less than 18 inches from the center of the rear
axle . the weight bar for the front can be 24 inches from the front of tractor to the hang point and the tire can be up to 260 sq in flat plate in other words 16.9 x 38
