There have been a lot of posts on here about wiring up a kill switch using the trailer break-away type switched that Denny's carb shop sells. I haven't actually used one of theirs, but I have used this type of switch. I am going to try to post a wiring diagram that shows how you can hook one up using a Single Pole, Double Throw relay that is available at most parts stores. This method does not just "ground out" your ignition to kill the engine. Since the SPDT relay has both a normally open terminal and a normally closed terminal, you can use it to kill the engine basically the same as turning the key off. Plus, the current going to your ignition doesn't have to run all the way to the back of the tractor and back up to the coil. This method will work on MSD type ignitions as well. You just connect the relay between the ignition key and the small red wire coming out of the MSD box. Let me know if you all have any questions and I will do my best to answer them.
PS. The Relay has both an 87 and a 87a terminal. The 87 is for a normally open application and the 87a is for a normally closed application. In this setup, the 87a is used and the 87 is not used.
