American Farm Heritage Pull
Mike N Mo
Does anyone have info/rules/classes for the pull on July 29th at Greenville, IL? I've got the info for the Toughest G pull, but need to know
what additional classes there including cut/top-cut/uncut tire classes, hitch height, MPH, etc.
Thanks, Mike
Here's what I found out so far. The rules will be Southern Illinois Pullers rules. I was unclear after talking to Brent about cut/uncut/topcut tire classes, but he is to send me a packet of info. Below are the 2016 rules I found for the Southern Ill Pullers from their facebook page. If someone has different/updated info please post as I don't wish to put out incorrect info.
So il rules
General
1}Drivers under 16 must have parents consent
2}No alcohol fuel,diesel an racing only
3}wheelie Bars Mandatory 32in back 10in off the ground 4in
x 5in pad
4}Kill switch or air shut off required
5}All weights must be secured
6}No weights can extend behind rear of tires
7}No weights or brackets directly above hook point
Farmstock 1 Same as Weast Alton
Farmers 4mph Top Cut
1}15:5/38-16:9/30 tires up to 6500lb
2}No radials or duals
3}No Moline 800 or like jugs/heads
4}No Red Diamonds
5}No fabricated Adapter Plates to install Motor
6}20% over factory RPM
7}Stock or Reproduction Manifolds
8}Must have same number of barrel heads and draft direction as from oem JD A,B,G,may use factory 50,60,70 JD or like model two barrel head,manifold, an carb
9}Must retain factory wheel base
10)Tractor must have been in production before 1958
11)20" max draw bar height
12)T/A may be used once
13)Weights or bracket can only extend out 11ft from center of rear axle
Open Classes
1)4mph open 1959 & under
2)6&8 mph classes 1970 an under
3)WC,WD,@WD45 use D-17 rpms as May other makes an models to upgrade to 1958 specs
4)No Turbos
5)800 jugs,Red Diamonds,ETC. Allowed
6)20% over rpm
7)Tractor may be newer as long as no changes were made after 1958/1970
8)18:4/38 tires no radials,Aluminum Allowed
9)Manufactured Manifolds allowed,same number of barrels/direction as OEM,JD-A,B,G allowed upgrades to like models of 2 cylinder era
10)TA -1 shift
11)Factory wheelbase must be retained
I talked to a somewhat local puller (to Greenville), and he told me there would be 15.5X38 topcut classes, 4MPH, 20 in. hitch; and fullcut 18.4X38 tire classes, 4&6 MPH, 20 inch hitch, using Southern Illinois rules (posted below)
