johndeeregreg
hi all, i do a little farm stock pulling with a JD 720 in 8500, 9500, and 10500 mostly on dirt tracks with a couple gravel, right now i carry all may weight on the rear of the rear axle, with a bracket up front that i throw some on as i think i need, my question would i be better off to have a belly bar to hang my weight on instead of everything behind the axle? typically i spin out but on if i get on a good tight track i can go till out of power, think at that pull i had about 600# up front and it was still off the ground. not sure where i would mount one if i were to put one on, would probably have to go off frame in front of flywheel. is it worth the effort or should i stick with what i have? any suggestions on what works or don't are appreciated as well as any pictures would be good.
