Looking for fast gears for moline gvi or 705 or 97 Massey
bryan bailey
New User
I'm in need of replacement transmission gears for gvi moline or 705 or 97 Massey. I'm at about 17 mph at 3200 rpm now in 4th would like to get closer to 25 if possible. Hoping someone out there might have what I need thanks Bryan 937-215-7188
Lawrence Wilson makes them. I spoke with him a couple of years ago about a 2-over 4th. He also offered a set that made 2 and 5 over. I have a friend near me that happened
to have a 2-over set on the shelf from Ron Perry, so I bought those, and am installing them now. I think Lawrence speeds up the bottom shaft, which makes 2nd gear your
fast 4th, but it also makes reverse REALLY fast. 2nd is the strongest gear in the transmission, and the step-up gearset from him installs next to the front bearings, so
shaft deflection is less of a problem. The ones I'm using replace 1st gear, so both of the double gears need 1st machined off of them, and an additional shift fork
installed on the 1st/4th shift shaft. This doesn't mess with reverse, but since 1st gear is more toward the middle of the trans shafts, some deflection can be expected.
For my use, this works out better. You can expect to pay anywhere from $1000-1700, depending on what you need.
