Waukesha Small Chamber Casting #
A.P.
I am looking for the casting number(s) for a Waukesha 195GK with the smaller combustion chamber. I've been told the combustion chamber in this head is the same as found in the Massey 1100 gas head. I would appreciate it if you can help.
I have had a number of these 195 engines apart the only ones with a small chamber area were 1100 massey heads , i had gas and lp engines apart all had large chamber design 1100 massey heads have small chamber but some people will say otherwise
Don't know casting numbers, but, there were two different compression heads used. The heads were shaped differently. One has rounded corners: the other has square corners. Maybe only square on one end. Can't recall for sure. Been a while since I messed with any of these. Seems the square corners heads were higher compression. Just need to cc one if you find it. Higher compression heads not real common.
