Im wanting to remove the hyd under steering column but keep the power steering. My question is if I remove all the flow control valves and leave the sides left and right to support the steering and hood.... can I make plates to cover the holes on the left side... will this just cause a hyd lock or will the hy trans just re circulate into the transmission?... I would prefer to eliminate the valve on the bottom also but the top three valves for the hyd valves and fast hitch would be sufficient. I was thinking this way I could keep my power steering and reduce weight and stay in div 2. Ive built a box to support the column but Im afraid in div2 that someone wouldn't like it and not to mention I wont have power steering. any info on this would be appreciated if someone has done it themselves. open to other ideas as well if someone has done it a different way. thanks
