I have a 460 split that Im building... Im putting in new heavy duty ta... I would like to remove the pto shafts from front to all the way out the back... but Im curious how the planetarys in the ta would get lube if the shaft isn't there below to sling oil up to ta housing. would it be better to just leave the shaft there and remove pto off the back... Ive got it apart and would be nice to take the shafts out and remove weight gain horse power. It would be a lot less rotating mass but Im just afraid the ta would end up running dry... the hyd pump is also going to be removed so Im thinking its not possible to remove the shafts unless someone has some pointers to point me in the right direction... I thought about sealing off the hole in the ta housing and filling with oil from top cover and putting a magnet in there but this would be worse than just leaving shaft in in my opinion. advice would be appreciated. thanks
