Offset grind c301 c153 rod question
mfro75
My question is to anyone who has done this I have a true c301 block looking to offset grind crank and use c153 connecting rod.. I've seen post where guys have used this combination with success.. my question is with I have to do any grinding on the block for clearance... and if so how extensive is it?
When you offset grind: your using a smaller diameter rod journal. No grinding needed unless you came up with a real off the wall rod to use. Your not lengthening the crank any:
