BIGOL880
I had a bad gas tank on my Oliver 77, I mounted a tank on the front weight bracket lower then my carb. What is a good fuel pump to get the fuel back up to my carb now that my tank is lower?
Don't use a specific brand name but make sure i use a low pressure electric pump. 1-2.5 psi. More than that can override the carburetor inlet needle value and cause flooding. At least that is what has worked for me
We use a Holley with a regulator. You can set the psi to what you want. Got ours at Advance auto, But Summitt also has them. Don't forget to put a valve at the tank..
No It will be fine. Wire it so when the motor is off so is it. Also plumb it with a shut off at the tank, then a in line filter, then the pump after the filter. Check to see if you need a fuse in the wiring?
