Wheel Weights on a Pipe
I am wanting to put some wheel weights on a 8" pipe...anyone built something like this ?...was wondering what thickness the ears welded to pipe should be to bolt in the holes on the hub...my hubs only have 2 holes if that matters...Thanks for looking
I have a set I made with a 3/8 mounting "ring". These are on hubs with three bolts, and they are about 2' long. Will hold 1000 lb of MH weights on each side.
How thick you need depends on how far out you need to go. 1/2 ears on two bolts, I would keep the pipe 16" or less. Need to know how much weight you plan on carrying.
