Massey Harris 44
Jdunlap
New User
Just purchased a 44 to pull with. I am need of some info on where
the timing should be and if I need to rejet the carb. Plan on
running div 2. Thanks in advance.
I have a 44 Massey I pull and I have the largest M&W piston made for it, a reground cam. If you are fortunate then you bought one with the big pistons in it. Years ago when I was a kid and we started pulling this tractor we took it from 4" flat tops to 4.062" M&W fire craters and only gained 3 HP. As it turns out these engines need a re-ground cam to make horsepower. I have a carb off a 55 if you are looking for a bigger carb.
