farm stock help
Make sure its tuned up & running as it should, gasket match & port the head & manifold. Longer rods w/cam regrind will make it run strong. Tin wheels & flat back to shed some weight & a adjust hitch help if your club alows.. Give Blackburns performence a call, Josh can make'm run ! What year B you plan on useing ?
running 1951 b new mw pistons rebuilt head rebuilt carb new dist and coil tractor runs great where I'm gona pull the 88 oliver is same class so looking for any advantage rear tires are at 11 psi run cast centers so she is heavy on her butt new clutch thanks
That heavy you'll prob be useing 1st gear witch is really low, if its a good hard track you might be ok. If you can get some weight on the front to hold it down that be good, get the hitch as short & high as rules let, i usally run 7-10 psi in tires depending on track, hard track-hard tire , soft track-soft tire
