Pics From West Mineral,KS Pull-Home Of Big Brutus
1206SWMO
Yesterday I and two friends were in West Mineral,KS for a tractor pull....It was overcast and chilly in the
morning... By noon the sun was out and it wasn't too bad...Lots of pullers were missing because of HS
graduations..
Heres some pictures..
1-2 Me pulling the 5 MPH 6500 class...As you can see by the end of the run i was a little high and could
have used another 100 up front..I hooked 4 times yesterday..
3-Ross Potocniks good running WC in the 5 MPH 3500 class..
4-Albert Potocnik made the long 4 mile journey to hook his 6000 Open D-17 with a 301 in it...It made a great
pass..
5-An Econo-Mod made a pass at the end of the pull..
6-The last hook of the day was a new big block Chevy TWD from the Weir,KS area..It put lots of dirt in the
air..
7-An 8N Ford showed up to play..
8-This B JD almost took it out the end..
9-10--The Sullivan brothers from Medoc,MO had their G JD's there..The last one pictured beat the other G all
3 times if I remember right..
11-A good running M Farmall from SE KS..
12-A WD AC from the Lockwood,MO area..
13-14----After the pull was over we took a 1.5 mile drive west over to see Big Brutus...One of my friends had
never seen it..Heres some facts about it..
1-Largest electric shovel in the world.
2-160 feet tall
3-Weighs 11 million lbs
4-Bucket holds 90 cubic yards or 150 tons
5-Top speed is .22 MPH
6-Cost 6.5 million in 1962..
7-It takes 1200 gallons of paint to paint all of it.
Yes,there are quite a few pulls coming up..
Medoc,MO May 28th 1 PM Black Widow Sled (15 miles north of Joplin)
Mapleton,KS June 11th 1 PM Crazy Man Sled -pulling classes from 3500 to 14,500 PH 620-743-3691 for info..
Adrian,MO Show - June 24 6:30 PM up to 5500 classic 1939-59
June 25 6:30 PM 5501 and over classic 1939-59
June 26 3:00 PM 1939 and older rubber or steel--- must pull 1st gear all 3 days-weight
% pull for mostly stock tractors....I'm planning on pulling 6+ tractors..The show has their
own sled...MM is the feature tractor.
Cherokee,KS June 25th 1:00 PM Black Widow Sled
Chetopa,KS July 4th 9:00 AM Black Widow Sled-will have to get up early that morning
Golden City,MO July 9th 1:00 PM Black Widow sled
Girard,KS Fair August 5th 6:00 PM Black Widow Sled
Sheldon,MO Picnic August 20th 3:00 PM Black Widow Sled
Ft Scott,KS Show August 27th 4:00 PM Black Widow Sled
Ft Scott,KS Show August 28th 1:00 PM Black Widow Sled
Stotts City,MO Sept 2nd 7:00 PM Black Widow Sled
Cherokee,KS Homecoming Sept 11th 1:00 PM Black Widow Sled
Cherokee,KS October 29th 1:00 PM Black Widow Sled
Chetopa,KS Pecan Fest Nov 19th 1:00 PM Black Widow Sled
Are you guys pulling 3mph for div. 2 and 4mph for div. 3? I have a B Allis that I may haul over to Chetopa and pulls in that area. Its low gear is just to fast for div. 2. Thanks
Doesn't really matter,but it WASN"T the largest electric shovel built.The BIG MUSKIE was almost 3 times bigger and THE CAPTON was twice as big.It is the only one still in existence tho as the others were scrapped in the late 90s.
They mostly pull at 3 mph and 5 mph with classes starting at 2600 lbs.....Call Jim at 620-762-2459 or Vernie at 620-762-6323 for info on pulls,classes,rules,tire size-etc..I'm sure that everyone would be glad to see you come and pull..
Yes,I knew at one time that there were several bigger ones but as you said it doesn't matter now as they are both gone which is a shame..Big Brutus is the largest survivor...
