case cc compression
I have a case cc with 4in pistons and a 5505A head. Just wondering what compression I should have on each cylinder? The rings are all brand new. Thanks in advance.
My dc has 200lbs with a 5505a head but 4.875 bore or 4 7/8 1 would
guess yours would be 160-170 what are you reading are you putting a
little oil in the cylinders and have you run it enough for three rings
to break in
(quoted from post at 03:53:47 05/13/16) My dc has 200lbs with a 5505a head but 4.875 bore or 4 7/8 1 would
to break in
I'm pretty sure that I have run it enough. What kind of oil and how much in each cylinder?
my DC has 92psi but has m and w 4 1/16 piston and they run on the low side. I have a another with the 4" but low compression head and also makes 92 psi. If I had to gess u will be around 100psi
mine actually has 194 to 196 just a half a teaspoon engine oil run tract0r till warm turn fuel off run till out of gas pull coil wire off take all 4 plugs out put a squirt of oil in each cyl open throttle all the way and test each cylinder on fully charged battery
Sorry my comparison isn't right I have flat top pistons that come flush with the top of the block so like others have said 110 to 120
