Saturday was a beautiful sunny day in eastern Kansas...The temperature was in the low 80's and it was a good afternoon for a tractor pull which was held at Bronson,KS..The numbers were down some as lots of people were in the field..The sled was "The Black Widow" from Columbus,KS..Their next pull will be West Mineral,KS on May 14th..
1-Me pulling my U MM in the 5500 Open class....I ran 3rd gear and was able to spin it out....It had all that it wanted..
2-Me again pulling the 6000 lb 5 MPH class..I was the lone MM puller there...
3-Kenny Storrer from Iola,KS with a tough little 66 Oliver that pulls at 2600 and 3000..Years ago Kenny was the Oliver dealer at Iola....Back in the early 1970's I pulled a Wards in the 4500 class against Kennys strong 77 Oliver....Kenny is a former NATPA points champ with his 88 Oliver..
4-Lee Wegner from Parsons,KS on Mad Max trying to run Kenny Storrer down in the 3000 lb 5 MPH class....This a stout little 20 Massey..
5-My neighbor ( 5 miles east as the crow flies} Mike Houston had several good hooks with his WC Allis...He stays busy as he also has (7) garden tractor pullers and a mini rod.
6-A good running AC from Lockwood,MO...
7-An H Farmall from Columbus,KS..Dont let its looks fool you..
8-Pulling veteran Eugene Rogers from Fontana,KS with a big cube 28-44 Oliver...This man is 81 years young and has pulled for over 50 years...This tractor was a 1999 NATPA points champ....I first met Eugene around 1970 when he pulled a 435 JD with the KTPA...He had one of the first 5000 lb Hot Rod tractors in Kansas which was a 101 Massey with a 427 Chevy...He then built a 55 Massey with a V-12 Allison and once pulled at the NTPA Super Pull in Indy..He was a Region 5 NTPA points champ..
9-Frank Grosshart from Pleasanton,KS with his Super C....Back from about 1968-1980 Frank pulled a M Farmall and 560 Farmall in the stock classes..He took off over 30 years and is back at it..
10-A nice 560 diesel from Columbus,KS..
11-Macie ? Snyder from Independence,KS on her C Farmall..
12-A 300 IH owned by the Snyders from the Mapleton,KS area....Mapleton will have a pull on June 11th..
13-Another 300 IH owned by the Snyders from the Mapleton,KS area...
14-Eugene Rogers in the pits..
