Aluminum front wheels
77diesel
Alright guys I want to put weld pro star wheels on the front of my 36 JD A it has original spoke front wheels currently what do I need to do to change over. Thanks!!
(quoted from post at 20:14:43 12/08/13) Alright guys I want to put weld pro star wheels on the front of my 36 JD A it has original spoke front wheels currently what do I need to do to change over. Thanks!!
My brother makes hubs. These are for oliver.
$485/pr
(quoted from post at 10:35:52 12/09/13)
$485/pr
those are nice, do you have them for a 77?
(quoted from post at 13:56:38 12/09/13)
$485/pr
Thank-you,
Yes, these fit 66,77,88,supers,770,880. These are stock replacement that use stock bearings with a automotive lip seal
Can do 5 bolt, and move the hub face so wheels are tight together. Weigh 6lbs each
Can make them for those red tractors you like too... Lol
What wheels are they set up to run? Standard six bolt Oliver/ag wheels, trailer rims, automotive (which pattern)? I would be interested in a set depending on what rims I can run.
My email is open
(quoted from post at 08:21:05 12/10/13) What wheels are they set up to run? Standard six bolt Oliver/ag wheels, trailer rims, automotive (which pattern)? I would be interested in a set depending on what rims I can run.
My email is open
All hubs are made to order, and fit the wheel of your choice
The ones in pic are direct factory replacement 6 bolt on stock oliver spindle, and will accept stock dust cap, and bearings
can be made in 5x5 or 5x4-3/4 bolt pattern, and offset the flange for a different back space rim
Can be made for any spindle, trailer, car, JD, AC, IH, Ford
[email protected]
YES, can be made for any model.
These wheels are similar to ones I am putting on my 88 oliver that are
http://www.summitracing.com/parts/wld-90-54340/overview/
(quoted from post at 20:18:46 12/10/13)
6pack quotes his brother makes these hubs and I have been unable to contact his brother. can 6pack contact me with way to find out more about the hubs.
