I have a late Super M that I want to put on a diet...enough to make 4500 comfortably. I have done several things to knock the weight down since I bought it last year. I have found a set of w6 axles and a 1939 Farmall rear end. Ive been told the 39 M rear housing is considerably lighter than late model Ms, but the bull gears and other internals are lighter and weaker as well. The only bull gear failures I have heard about on Ms are the 1939 and early 1940 models. Those of you guys that pull lightweight Ms...what is your take on that rearend? Should I keep my Super M rear and just swap W6 axle housings? Any input appreciated
