brutus49DC
I had a good time there and for the most part things went well but it looks like Jim Young needs to learn the concept of fair treatment for ALL colors(or better yet stay home)! I also wonder if the hocus-pocus electronics on his tractor needs further scrutiny. He says the rpm checker doesn't work on his tractor but yet it's ok to dq others using the same equipment. Over is over and I'm not arguing that point however when he was asked to check another tractor (that doesn't have a positive stop) he said he didn't have to if he didn't want to. That was a formal protest and should have been acted on. Also those of you that are having your rpm's read by the sled are wrong in setting them over the max because the loads brings them down during the pull. The rule is based on Hi-idle no load rpm's -PERIOD. It's too bad so many have to spend most of their time devising new ways to screw the system. Why don't you instead go, play fair, talk shop with your old friends, make some new ones and have a good time? That's what I do.
