Disc Brakes
If anyone is using after market disc brake systems on there farmalls, could you post pictures and parts used ?
We have a 300 utility, and the brake aren't very good.
Thanks Al.
Hi Al, how are your brakes operating, grabby or just not enough drag, I have a milling machine and work on lots of them. I have done a lot of mine still have a couple more to go. Call me 412-812-5632 if you need a hand with them.
On my 460U I turned the stock disc in lathe and removed all facings. I them used 4 piston calliners from wilwood and their brake pedals. Made brackets to hold everything. Will hold tractor on ramps or backing out of spin out holes easy.
I just bought clapper and rotors from front of an escort,welded them to stocks center, made mounting brackets Willwood pedals and braided lines super light compared to old band and drum setup
