310 in and 880
Your 880 bell housing, backing plate, flywheel, clutch will all work on the 310. There's something you have to do to the water pump also I don't remember exactly might just had to run a smaller fan. If you have the over / under and want just the straight drive shaft then a bell housing from a 770, 880, 1600, 1650,1550 will work
Its been a while but seems like you use a clutch from a 75 or so 400 Chevy 4x4. We used a 77 flywheel so had to drill and tap new holes. Be sure and balance everything.
