Farmall lp heads
770puller
Are the originals better then the reproduction? Does anyone have either for sale ? Found head on my farmall cracked and trying to decide what to get to replace it, motor is 309cubes run 10-20% over rpm basically a 2t tractor
I have used several of the new lp heads. I did have to replace one valve guide before I used it because the valve was way too loose. The casting quality isn't as good as the original but most originals have been cracked and plugged or welded. I just buy the new ones and check them over carefully before I put them together
