Crane Cams XR3000 ignition
JHH
Has anyone used this ignition system? We have one that is giving us problems. Had an xr700 that the coil went bad and replaced it with a new xr3000 and new ps50 coil. Ran about an hour and was sitting idling and died. Light still blinked and made about 1/4 inch spark but not enough to run.
(quoted from post at 09:09:52 10/13/15) Has anyone used this ignition system? We have one that is giving us problems. Had an xr700 that the coil went bad and replaced it with a new xr3000 and new ps50 coil. Ran about an hour and was sitting idling and died. Light still blinked and made about 1/4 inch spark but not enough to run.
If Crane tech is like MSD, they will take a suspect box or other component, check it out and if practical, make repairs. I wired an MSD box from memory which didn't work for more than 5 minutes (memory or the box), sent it to MSD service, they rebuilt, and it worked fine.
