GCTC Pull at Chouteau..
Topsarg
GCTC will pull tractors at Chouteau, Okla this Sat the 19th starting at 10AM. The reason for the early start is the Classes that didn't finish at Lincoln, will pull and in sequence..Pull Chouteau first, then Lincoln.. the Lincoln classes will be open for entries as well.
James Grossman is hosting and the Equalizer sled's going to be on hand to drag us down...should be a ton of fun.. Info Call Jim @ 1-918-483-7775
