Best updraft carb?
I have a 301 bored .60 over with a cam and straight valve truck head in my 460. I run between 4000 and 5000 rpm and am in search of a bigger carb. It just cant hold the rpm very well under a load and loses it's momentum very fast. I'm pretty sure a NAR6B would be too big for me but what is my best bet?
Thanks.
I agree the 7700 combine carburetor works great but are hard to find and are expensive , but a reworked stock carb with larger throat and v
venturi would also be an alternative.
"Best Updraft carb" I ever saw or worked on was on an Aircraft radial engine and had a venturi size of 100 Square Inches..
Sure made a lot of HP...!!
