TENNESSEE / KENTUCKY THRESHERMENS SHOW - ADAMS, TN
Pull Dates: Friday 5:30 July 17
Saturday 1 pm July 18
Friday Classes
Steel Wheel: Light Steel, Light Medium Steel, Medium Steel, Heavy Steel
Farm Stock: 2750, 3250, 3500, 4000, 4500, 5000, 5500, 6000, 6500, 7000, 7500, 8000
Super Farm: 3500, 4000, 4500, 5000, 5500, 6000, 6500, 7000, 7500, 8000, 9000
K.O.H Farm Stock: 5850 (no tolerance, no super farm setups)
Saturday Classes
Farm Stock: 3500, 4000, 4500, 5000, 5500, 6000, 6500, 7000, 7500, 8000
Antique (1st gear): 3250, 3500, 4000, 4500, 5000, 5500, 6000, 6500, 7500, 8500, 10000
Open (6mph): 3750, 4250, 4750, 5250, 5750, 6250
K.O.H. 3950, 6150 (1st gear 16.9 tire max, no tolerance, cut tires allowed)
3 hooks per tractor each day
15.00 entry fee
50% money payback open classes (top 3)
100% money payback K.O.H. (top 3)
Tractors and/or classes are subject to random weight checks
Rules:
Farm Stock:
First gear only, 3.5 mph max, 18” drawbar height, weights must not extend past front wheels, 100 lb. tolerance, No pressed steel unless factory equipped, no cut tires, must have factory blocks, heads, Rpm – 10% over, ring or clevis, no side shields or chrome wheels, factory ignition (electronic pickup allowed)
Super Farm Stock:
1st gear only, 4 mph max, 20” drawbar height, weights can extend 11 ft from centerline of rear axle, 100 lb. tolerance, no cut tires, 16.9 max width up to 6000 lb, 18.4 max width – 6500 lb and up, wheelie bars mandatory unless farm stock tractor enters, any type of fuel, rpm – 20 % over, ring or clevis, aftermarket blocks, head, ignition, etc allowed.
Antique:
1st gear only – 4 mph max. 20” drawbar height, weights can extend 11 ft from centerline of rear axle, 40 lb. tolerance, cut tires allowed - 16.9 max width up to 6000 lb, 18.4 max width – 6500 lb and up, wheelie bars mandatory, any type of fuel, rpm – 20% over, ring or clevis, aftermarket blocks, head, ignition, etc allowed.
Open:
Same rules as Antique, except - Any gear up to 6mph, 18.4 tires allowed in all open classes
Friday Classes
Saturday Classes
15.00 entry fee
Rules:
Farm Stock:
Super Farm Stock:
Antique:
Open:
