John deere G starter
Delco part # 1113278 - used on early Powerstrokes.
Bobcat part # 410-12139
Gear-reduction Denso starter off a Deere 8000-series 6081 engine works good.
4430 Deere starter works good too.
Supposedly the 5.9 Cummins starters will work too. I've held several of them but never actually tried. They look like they would.
j. Here is the starter we use on ours. Friend in Muskogee has starter man make them from Cummins and changes gear to 10 tooth. Crank 860 ci G no problem. In process of cutting mounting flange so flywheel cover will line up. Lynn
(quoted from post at 08:28:10 07/04/15) Delco part # 1113278 - used on early Powerstrokes.
Which is the lightest? Any price comparison? Thanks.
