M counter bore filler rings
If anyone can fix you up it will be Gary Baker, it may challenge him to get you some that small. LOL.
He will probably see your post and check in.
Might be easier and cheaper just to get a head gasket that eliminates the need for the filler ring. Check with Murphy's Motor service
For a 4.125 bore M block. Shorten a old sleeve but leave enough to chuck in a lath and cut the ID at end until the counter bore ring comes off.
